Use the following procedure to view IS-IS accept policy information on the switch.
  1. Display IS-IS accept policy information:
    show ip isis accept [vrf WORD<1–16>][vrfids WORD<0–512>]
  2. Display I-SID list information:
    show ip isid-list [vrf WORD<1–16>][vrfids WORD<0–512>][WORD<1–32>]
  3. Display route information:
    show ip route [vrf WORD<1–16>]
    The NH VRF/ISID column displays the I-SID for inter-Virtual Services Network (VSN) routes redistributed with IS-IS accept policies, only if the I-SID redistributed does not have an IP VSN associated with it. If an IP VSN exists for that I-SID, the VRF name displays. If the I-SID is 0, the column represents and displays as the GlobalRouter.
    The existing IS-IS routes for Layer 3 VSNs continue to display as the VRF name of the IP VSN.
  4. Display the SPBM IP unicast Forwarding Information Base (FIB):
    show isis spbm ip-unicast-fib [all] [id <1–16777215>][spbm-nh-as-mac] [home|remote]
View IS-IS accept policy information:
Switch:1#show ip route vrf test
                    IP Route - VRF test
============================================================================                                                      NH               INTER
DST       MASK            NEXT      VRF/ISID    COST FACE PROT AGE TYPE PRF
1.1.1.5   255.255.255.255 1.1.1.5   GlobalRouter 0   0    ISIS 0   IB   200
1.1.1.13  255.255.255.255 Switch13  GRT          10  1000 ISIS 0   IBSV 7
1.1.1.200 255.255.255.255 Switch200 GRT          10  1000 ISIS 0   IBSV 7
5.7.1.0   255.255.255.0   5.7.1.1   -            1   7    LOC  0   DB   0
13.7.1.0  255.255.255.0   Switch13  GlobalRouter 10  1000 ISIS 0   IBSV 7
100.0.0.0 255.255.255.0   100.0.0.1 GlobalRouter 0   100  ISIS 0   IB   200
111.1.1.0 255.255.255.0   111.1.1.1 hub          0   111  ISIS 0   IB   200
Switch:1(config)#show isis spbm ip-unicast-fib
                                SPBM IP-UNICAST FIB ENTRY INFO
     VRF     DEST                              OUTGOING  SPBM    PREFIX  IP ROUTE
VRF  ISID    ISID    Destination  NH BEB  VLAN INTERFACE COST    COST    PREFERENCE  AREA   AREA-NAME
GRT   -      101     1.1.1.13/32  Switch13 1000  1/7      10     44       7          HOME   area-9.00.02
GRT   -      101     1.1.1.13/32  Switch13 1001  1/7      10     44       7          HOME   area-9.00.02
 Home : Total number of SPBM IP-UNICAST FIB entries 2
 Remote: Total number of SPBM IP-UNICAST FIB entries 0
Switch:1(config)#show ip isid-list test
                                 IP ISID LIST
List Name                        I-SID                VRF
test                             1                    GlobalRouter
                                 3                    GlobalRouter
                                 4                    GlobalRouter
                                 5                    GlobalRouter
                                 10                   GlobalRouter
                                 22                   GlobalRouter
All 6 out of 6 Total Num of Isid Lists displayed
Switch:1(router-vrf)#show ip isid-list vrf red
                                 IP ISID LIST red
List Name                        I-SID                VRF
test1                            11                   1
                                 12                   1
                                 13                   1
                                 14                   1
                                 15                   1
The following table defines parameters for the show ip isis accept command.
Variable
Value
vrf WORD<1-16>
Displays I-SID list information for a particular VRF by name.
vrfids WORD<0-512>
Displays I-SID list information for a particular VRF ID.
The following table defines parameters for the show ip isid-list command.
Variable
Value
vrf WORD<1-16>
vrfids WORD<0-512>
WORD<1-32>
Displays I-SID list information for a particular I-SID list name.
The following table defines parameters for the show ip route command.
Variable
Value
vrf WORD<1-16>
The following table defines parameters for the show isis spbm ip-unicast-fib command.
Variable
Value
all
Displays all IS-IS SPBM IP unicast Fowarding Information Base (FIB) information.
home
Displays the IS-IS SPBM IP unicast FIB information that the system configures in the home area.
id <1-16777215>
Displays IS-IS SPBM IP unicast FIB information by I-SID ID.
remote
Displays the IS-IS SPBM IP unicast FIB information that the system configures in the remote area.
spbm-nh-as-mac
Displays the next hop BMAC of the IP unicast FIB entry.
